Hi, looking for some advice please!
I currently have an old three-wire Potterton room stat that I'm replacing with a Siemens RDJ10. The stat is linked to a Honeywell ST6400, and I want to override the CH timer controls on this. This is then linked to my ancient Stelrad Ideal Excel RS60 (1980's model, not the newer one).
My question is, what wiring do I need to change? As it stands the new stat is just ignored by the boiler, so I assume there's another step needed. I've already used the forum to correctly wire up the new stat (common to LX, switched live to L1, neutral not used and terminated). I'm attaching a picture of the current wiring pattern, the grey one is the one that goes to the room thermostat if that helps:
Any ideas/advice gratefully accepted, thanks!
