S
Shutpa
When toilet wouldn't flush I replaced the syphon a few mpnths back. Now, it wont flush again and I'm wondering if there is an alternative to the syphon. As far as I am aware, the diaphram cannot be replaced on its own.
Thanks for you reply! Had a look and there is nothing in there that shouldn't be. I did see that the water level is slightly (about 10mm) below the level marked on the side of the cystern though. Would this be a possible cause. What gets me is that sometimes it will flush every time and sometimes it takes half a dozen triesanother thing to check is that there isnt a blockage restricting the flow into the pan, either trapped in the syphon or where the water flows into the pan,
Hi Andy, I'm sorry I missed this post first time round. However, as you will read below, the problem has been solved. Thanks for your contribution.Try one of these.
http://www.screwfix.com/prods/63618...gs/Fluidmaster-Leak-Sentry-Toilet-Cistern-Kit
Very easy to fit.
Andy.
Adjust the inlet valve to bring the water up the 10mm to see if that has an effect on the problem before you go to any bother/expennse with syphon changing.
