Replacing abutment flashing on rendered wall
23 Apr 2007
I need to replace the abutment flashing on my roof. The abutment wall is rendered all the way down to the double lap roof tiles. From what I can work out I need to..
Remove about 100mm of rendering above the tiles.
Fix flashing soakers.
Fix step strips of flashing into the exposed motar joints.
fix a rendering stop above the line of the stepped flashing
Render up to the rendering stop.
Is this correct?
Thanks,
there's also a chimney breast mid way along the abutment that the flashing has to go arround. How do I do the flashing around this so that standing water doesn't collect on the upper side of the chimney in the corner between the chimney and wall?
Thanks, didn't spot page that when I looked at the site!
