Hi there,
I have just bought a Grade 2 listed cottage and we're having the Aga removed and replaced with a gas range. As beautiful as it is, it really isn't practical financially. For now the new range will be located in the same place as we cannot afford to do a kitchen refit for the foreseeable future.
Being that this is a cottage the ceilings are very low and I'm wondering what our options are for extraction. Currently the aga is piped out into the front chimney stack (see images below) and ideally we would use that hole to extract through. Would a circular extractor fan (just inserted into that hole, not over hobs) be powerful enough? Can you get super powered ones?
Being that the house is listed and made of cob we may have some issues with ducting out the ceiling and across into chimney. Do pipe style extractors (such as in the bottom two images) do a good enough job? Would it be possible for one to come in through that existing hole then bend downwards above the hobs? Or is our only option a big old extractor hood?
I hope this makes sense, and thank you!
Images of house:
Images of extractor "pipe":
Images of house:
