- Joined
- 1 Feb 2019
- Messages
- 9
- Reaction score
- 0
- Country
Hi all,
I've been watching a number of videos on YouTube and was hoping I could attempt replacing radiators myself.
The radiators themselves are single panel & imperial size. I was going to replace with similar sized metric and hope there's some wiggle in the pipe, or if not use an extension (I have some pipes in screed!)
Some rooms can feel a bit cold, however expect it's because the radiators are very old as the BTU outputs of similar sized rads seem to be overshooting the rooms.
I eventually want to replace my vented system with storage tank to a combi boiler, but will use a gas registered person for this.
I have a few questions now...
What do you think the best BTU calculator is?
Is it recommended to replace the olives - or should the existing ones be OK with the additional pressure providing I remember to use a bit of jointing compound on those and PTFE tape on any threaded bits?
Can I do more than one radiator at once, or is it recommended to only replace one at a time?
Is it recommend to flush the system / clean F&E tank before doing this sort of thing?
Are there any other things I should be considering in radiator replacement and eventual boiler upgrade? (I'll add inhibitor once all the radiators are filled!)
Bearing in mind I'm going from a vented system to unvented system - might it be worth using a plumber to do all radiators & the combi boiler (just wondering if it's likely I'll cause more problems!)
Thanks very much for any help!
