Replacing all the floorboards in a room
4 Dec 2006
Berkshire
I'm doing up a Victorian house and need to re-do the floor in one of the bedrooms. There's a big chuck missing where somebody has taken out the fireplace and the rest of the boards are in a really poor state with chunks taken out etc.
What would be the best wood to use? Can i just take up the old boards and lay T+G pine from one of the sheds or will this have problems with load bearing? I've only ever seen that stuff laid over floors, not over joists.
Any advice or handy tips appreciated. In my head it seems quite a striaghtforward job so that means there's somethig I;ve not thought of!
Cheers
Bob.
Ye no problem. Just got to check joist spacing to the thickness of board you need. You may want to consider plywood sheets to. Faster to install, Less chance of squeaks, more stable, less draft , the list goes on!
Shed t-G will do the job, but you might get it cheaper at an builders merchants, after all have you seen the sheds construction of there sheds :LOL: even the 3 pigs would not stand any chance with the wolf :LOL: ;)
check the thickness as shed bought wood is in general 3mm thinner than your woodyard 18 or 19 compared to 21 or 22
All the other bedrooms are keeping the bare boards so I'd like to go with wood for this one as well. Plywood doesn't look as good so T+G it is.
Thanks for the advice. I'll find a timber yard and do it properly, hopefully this one will last another 120 years.
You will probably not be able to match the old boards, so you may end up doing one room in new, unless you need so little that you can plane or thickness it to match. You can use the good salvaged boards to repair your other rooms, though.
you will need a pair of these
available from a hire shop.
also, don't go mad and rip the old floor up entirely, just take a few up at the end you are going to start. this way you will be able to work comfortably on the existing boards and have somewhere to put your tools.
if the boards are to be decorative then you can also hire a hidden nailer which sits in the tongue and pins the board invisibly. ;)
