Replacing an existing single oven.
I would like to replace my current single oven.
The oven is currently connected in the following way.
32A MCB in the Legrand fuse box, 6mm2 wire to a 45A DP oven switch above the worktop, feeding a single un-switched outlet below the work top. The oven is currently connected via a 13A plug to the outlet.
The new oven is an AEG BP5304001M rated at 3.5kW. This is a higher rating compared to the existing oven hence the questions below.
My question is can
I am intending on getting an electrician to carry out the work but this is mainly for my understanding.
Thanks very much.
My question is can
- the Legrand 32A MCB fuse be replaced with a 16A version.
- The socket be replaced with a fixed cooker point connection.
Thanks very much.
