i need some advice on replacing a rotten 40mm external door. I cannot afford to buy a new door and have very limited funds. I acquired an old door from across the road as someone was having a new plastic door fitted. I measured it up to make sure it would fit and it will after some cutting down. I forgot to measure the thickness ( DIY is not really my thing ) It is 44mm thick and the old door is 40mm thick. The old door sits flush at the moment but i think the door frame is probably 44mm deep as there is a brush type door insulation fitted. I want to keep this insulation in place if possible. Is this replacement going to look ok or are there too many issues for it to work properly. What are the things i need to take into consideration. The replacement door also seems to be much heavier ( both doors are hardwood mahogany ) and i am really struggling to even move it around.
thanks
darrell
thanks
darrell
