Replacing an integrated dishwasher
7 Dec 2008
Cardiff
Hi, I have an Electrolux integrated dishwasher that i may need to replace and it is likely to be a Bosch itegrated unit.
Are there any problems I should be aware of before buying a replacement and fitting. I know full size units vary very slighting in width, would this create a problem when refitting my wooden panel to the door?
Cheers
The wooden door fronts are usually larger than the appliance so you should have no problem there.
With some Bosch machines I have noticed that they are slightly deeper 'front to rear' which can cause problems with aligning the front with the panels either side.
This is mainly if the waste pipe is put behind the appliance 'Grrs at peeps who do that'
