Hi. First time poster so I hope I'm asking this question in the right place.
We've just moved house and one of the doorways into the lounge was door free. The frame wasn't plumb and the stop was fitted for an old ledge and braced door. In addition the stop was molded as part of the old frame so I couldn't adjust it. The opening was approximately 770mm wide.
I have removed the old frame which was colossal. Each plank was 65mm wide. Having remove it I have an opening that is 900mm. I don't have room to fit a door that is any wider than 762mm
I bought a softwood door lining kit but this is only 250mm wide. My question is can I use this in conjunction with a baton to pad out the gap and finish with a decorative architrave or should I replace like for like and buy thicker planks and and construct a frame that more closely resembles the one I've taken out? Or is there another option?
Thanks in advance for any help.
