Replacing an outside light -help!
26 Sep 2006
Fife
The old outside light was rusting away so I've just bought a new one. I thought a pretty simple job - but...
The old light was connected to a 'mains' grey cable (with earth) using insulation tape (not a junction box) and there is no conduit through the wall - doesn't seem too professional.
But the light switch box contains 3 switches (one for this light, one for the hall and one for the landing/stairs - this one can also be operated from a separate switch upstairs). This does seem to be original. The house was built in the early seventies and as far as I know hasn't been re-wired. The consumer unit is one of the old type - with push in fuses - you replace the wire.
The fitting instructions for the new light (PIR one) says 'electrical supply must be protected against short circuit by a suitable rated fuse (3 or 5 amp fused connectuion unit ) or a miniature circuit breaker not exceeding 16amps. This product should not be wired directly to a ring main.
Does anyone have suggestions? I have no idea where the wire runs and can't just replace the switch with a fused one. Is there another way - putting some type of fuse into the wire before connecting it to light? (there is quite a lot of spare wire you can pull out the wall) And would would happen if I just connect up the new light and not worry about it?
Help.....I can't put the old one back ( it fell to pieces) - so have the wires wrapped in insulation tape stuffed into the hole in the wall- not very weatherproof...and its raining...
Your lights should be on a five amp circuit (white spots on the fuse) already...
Sorry for being thick - but does that mean I can just use the existing wires ...is a ring main different from a lighting circuit?
It's not a 500W halogen security thing - its a max 60w bulb, fake lantern thing with PIR
Needs .4s disconnection time which internal lighting doesn't require but ring main does. I'm only a plumber though. I would think that a fcu off the ring main appropriately fused would do, and make sure the t n e is protected from UV rays, where it comes out of wall put a u bend on it so that rainwater runs off it and not into the hole in the wall. I expect there is a sparkie term for what for want of a better name I am calling a u bend.
Thank you all for the help...
Have now got (pregnancy) brain into gear and understand what you were telling me.... I'm very nervous about electrics - a flat I rented years ago burned down because of an electrical fault -I was out at the time but if I had been there and alsleep I would have been trapped five floors up...
Wired it into existing wires - if it blows the fuse in the consumer unit I'll live with it...
Thanks again
Supprised a plumber knows that :) (though IIRC re: the s/o, you can have 5 secs if you keep touch voltage below 50v - but stick to making them discon. in 0.4 and thats fine and good :) )
I'd be supprised if the existing supply didn't meet the requirements for 0.4 sec disconnect, but as the OP wont have an ELFI tester we can't know
I'd call that a drip loop
Thanks for the extra help, I welcome you good folk puting me right I am only touching the surface and welcome a little guidance.
Paul
A .4s disconnection time is only req, IIRC, for socket outlets (413-02-09) and kit installed outside the earthed equipotential zone (471-08-03) - from the OSG, so I think I've got the actual reg numbers the right way round, I'll have a look in the 16th Ed later. This means, that a light, fixed to the outside of the house, connected into the house earthing system, needs a 5s disconnection time.
