move new plastic soil pipe away from boiler terminal.
ps nice weeds in decking,have you sacked your gardener.
or leave that bit in cast iron - that won`t meltmove new plastic soil pipe away from boiler terminal.
I'd replace the lot, you dont know the condition of the bottom section and if its leaking where it joins the drain then that can cause problems. Chances are the boiler will need replacing long before the stack and any new flue will be smaller than the existing and thus further from the stack. (Also provides easy connection for condensate drain from any new boiler.) Cant really move it as you say due to position of the drain, and bends in wet section of the stack are frowned upon unless absolutely necessary.
To connect to existing drain, carefully expose the base where the CI joins the clayware. It may be necessary to scrap existing bend at the base and replace with a long radius plastic bend, either way you'll need a suitable connector from 110mm plastic to clayware. I'd expect to find salt glazed drain, so choice of connectors available. Wickes have one available 'off the shelf', or most of the plastics manufacturers do something suitable. There are also the 'Fernco' type, rubber collars with jubilee clips.
