- Joined
- 18 Aug 2015
- Messages
- 68
- Reaction score
- 4
- Country
I currently have a Glow Worm Flexicom 24hx condensing boiler (13 years old) on the ground floor and a water tank and vented expansion tank in the loft.
My home is a detached chalet style bungalow, ground floor and first floor with a small loft area above. It has 4 bedrooms with around 15 radiators and water under floor heating in the lounge. Three showers and no bath. The house was refurbished and new copper pipe heating/hot water system installed around the year 2000.
I’m aiming to have my boiler replaced and water tanks removed.
My plumber has suggest a Heat Only Ideal boiler, which means fewer pipe runs (otherwise he said he may have to remove walls/floors etc). With a Gledhill hot water cylinder and two expansion vessels in the first floor cupboard. Which is all fine, my only concern is there could be a risk of leaks as the pressure in the pipes will be more than they are at the moment.
Is this a very common risk and is there some way I can calculate this.
Also I’m thinking of getting an Ideal boiler with a Kw output of 30 instead of the 24kw existing one as sometimes one of our radiators at the end of the system does not seem to get very warm.
Our current system has a shower pump fitted so all showers can be run at the same time without noticing much difference. Our plumber mentioned that he would remove the shower pump and we might not be able to run two showers at the same time, or if we did we would notice the difference in pressure. Maybe I could ask him to keep the existing shower pump ?
Also does anyone have any experience of the Ideal Halo wireless thermostat ? (similar to Nest/Hive.)
Any advice appreciated, thanks.
