Hi
I need some advise. I have an old cast iron range cooker c1940/50
View media item 51887 its working fine and the chimney has been swept but the fire bricks at the back were cracked.
I was going to clean the soot and dust of and use a fire cement to patch them up but cleaning revealed the extent of the damage.
The heat has not only cracked the fire bricks but turned the motor behind them to dust and also the cement/lime mortor that was covering the bricks was also cracked and loose so it too just turned to dust.
Picture shows all the cememt removed from the bricks and the broken fire brick. View media item 51886 The black at the top of the picture is the cast iron throat and I have a flat iron plate that fits just on top of the fire bricks and meets the bottom of the throat.
View media item 51888
The fire brick is 42mm thick and 420mm wide and I think it is full size going down to the floor 320mm. To remove it I would have to remove the fire front and take grate out. I don't think either will come out without it breaking.
Could I use some kind of heat resistant air drying cement to fill the deep gaps between the bricks and fininsh with something like mouldable fire brick?
Anyone got a solution.
Thanks[/img]
Thanks[/img]
