Having recently moved into a new house only to discover that around half of the windows have broken hinges (never opened them during visits ), I decided to try to replace them myself as it looks straightforward enough..
They are all 'broke' the same way: basically the sliding part has snapped that joins the metal strips together so they don't close properly* without some wiggling about! The piccy below shows one of them
I'd some investigation on the net and found that I needed 10inch , 13mm stack height friction stay hinges which I duly ordered. However, when I tried to do the replacement, they are too wide and won't fit in the channel in the window. It seems that the windows in this house all have a channel width of 15mm but all the hinges on the net that I could find are 18mm
Does anyone know of anywhere where I can get hinges of this size OR am I on a wild goose chase and these hinges are custom made for these windows and I'll need to replace the actual windows/frames themselves (which I truly hope not as I'm skint after the move!!)?
Thanks for any help
Shaun
*[Edit:they don't actually close properly at all, you can feel the wind coming through them even when 'closed']
Thanks for any help
Shaun
