I want to replace a standard white ceiling rose / light drop with a new light. The new light is a complete fixture so all the wiring comes into its enclosure.
I think I can work out the wiring that will be in the existing rose (from b&q diy book for example) and I can see the 3 new wires on the new light to hook up.
My question is with the ceiling rose, where do I terminate and join all the various wires together.
Do I just use connector blocks?
If so, what sort of block e.g. I have seen 5amp, 15amp etc.
Or is there some other "rose-like" terminal block I need to get?
What would an electrician use?
