Hi there,
Thanks in advance.
I recently have been putting up some new lights , everything was fine til the last one ! I didn't touch the switches at all just the ceiling rose what I have is;
Bottom Stairs switch;
3 Core cable containing 2 red core and 1 earth, and a seperate cable with a single red core. The two red cores are connected to the L1 & L2 portions of the switch while the single red core goes to the bit marked Common. Earth is earthed.
Top Stairs;
3 Core cable containing 2 red core and 1 earth, and a seperate cable with a single black core. The two red cores are connected to the L1 & L2 portions of the switch while the single black core goes to the bit marked Common. Earth is earthed.
Ceiling Rose;
3 Core cable containing 1 red core, 1 black core and 1 earth, and a seperate cable with a single black core.
How do I connect this up ? have tried a few things with the result that I've blown the fuse twice and had the light in the permanent on position regardless of switch any ideas for the ceiling Rose wiring ??
Many thanks
Mully
Thanks in advance.
Top Stairs;
Ceiling Rose;
Many thanks
Mully
