Hopefully a simple question
I have to replace a direct 900 x 450 leaking hot water cylinder
The original had one cold inlet, one hot outlet, one immersion lower in the tank and a blanked tapping
I ordered a new one which came with three excess tappings, I got 1" BSP blank plugs from Toolstation, but they appear to be parallel threads
So the question is, do I need to fit fibre washers and ptfe the threads and or sealer
As they are parallel threads I suspect it requires fibre washers but wanted to be sure
