Hello all you knowledgeable folk!
First off please excuse my lack of knowledge when it comes to heating systems and electrics - I'm a computer geek not a DIYer
I've just received my Tado° system and need to fit it. It's replacing a Danfoss/Randall 3020P timer switch (no room thermostat). Boiler is a Baxi Bermuda Inset 2.
My current Randall 3020P wiring looks like this:-
The wiring diagram from the installation instructions looks like this:-
So, going from right to left: The first 3 are the mains supply:- Earth is Earth, 7 is Neutral and 6 is live.
4 is hot water on.
2 is heating on.
1 is neutral (but for what???)
The backplate for the new Tado° looks like this:-
Live and Neutral (terminals 6 and 7 on the Randall) are pretty self explanatory.
The tado backplate has no Earth terminal. I'm guessing this doesn't matter - I can just tape over the earth cable and leave it unconnected in the Tado box? Please confirm.
The yellow cable in terminal 2 of the existing Randall switch will go to the (H) terminal on the Tado.
The red cable in terminal 4 will go the the (W) terminal on the Tado.
What about the blue cable connected to terminal 1 on my existing Randall switch? According to the wiring diagram this is an 'extension' of terminal 7 (Neutral) so should I stuff the blue cable currently connected to terminal 1 of the Randall into the 'N' terminal of the Tado along with the Neutral cable coming from the mains supply?
Any help in this matter is MUCH appreciated!
Thanks very much,
Matt.
4 is hot water on.
2 is heating on.
Thanks very much,
Matt.
