Door lock/handle snapped and a bit of the actual door that houses the locking mechanism snapped also when I was opening the door with a screwdriver(!) so I couldnt just get a new door handle kit. I got a full replacement door off ebay and just tried to swap them. I took the two bolts out that hold the hinge of the exisitng door, thinking I could just swap it over and bolt the new door to the machine. Discovered that there must be some sort of nut or similar that the door hinge bolts screw into (sure i heard something drop inside the machine when I took out the existing bolts)and now cant get replacment door on as bolts have nothing to screw into. im wondering which is the best way to get inside the machine to find what it is the hinge bolts screw into. hope this makes sense!
thanks for any advice!
