I have an Ideal Classic conventional gas boiler with Drayton thermostat, valve, controller and pump.
The boiler is working absolutely fine with hot water but the heating won't come on. When I try pushing the three-way valve switch over to H, the boiler fires up momentarily but the switch forces itself back towards W.
So does this indicate a motor fault?
The valve is a 679H340-30L0, which I believe is one of the ones where you can't replace the motor. Is it likely to be salvageable? Any checks I can make to try and repair it before giving up and replacing it?
If I have to replace the whole unit, it is no longer made but some online stores say the Drayton MA1/679-3 is a direct replacement.
I'm slightly worried about having to replace it as this does not appear to be a clip-on type and DIY guides I've seen say I'll have to cut pipework if I can't get it off.
Now I'm fine about draining down the system (I've never done it before - but it seems a straightforward enough job), but I think cutting pipework is a little bit too daunting for a novice like me.
So does anyone have experience of replacing this model of valve? Have they had to cut out the pipework or was it not too hard to remove?
If I have to cut pipework, I'd rather call a pro plumber - but I lost my job a couple of weeks ago so can't really afford to do that.
