I have an oil fired Trianco boiler, the feed and vent come directly off one side of the boiler and the 28mm flow and return come off the other side of the boiler. Pump is in the return. System is microbore with two manifolds and a feed to the HW cylinder (open vented indirect HW) each of those three circuits is controlled by its own two port valve.
The F&E tank in the loft is right up in the apex of the roof well above the level of the outlet of the cold water tank which it's self is raised off the loft floor by 2.5 feet ( and which I replaced last year with a modern water bylaw one). The F&E tank is uncovered and uninsulated and rather flimsy. The vent pipe only sits on the edge of the tank it does not rise any sort of height above it before descending down.
I am replacing some downstairs rads so since I have to do the complete drain down of the descending loops, I am going to take the opportunity to replace the tank as well for a more suitable one.
So advise required on location and heigh please.
1. Should I position the new tank below the cold water storage tank or at the same level?
2. Is the a calculation as to what height the tank should be at?
3. How high should the inverted U of vent pipe go before descending back down?
Thanks for any help.[/list]
