I am replacing the old flange on my indirect hot water cylinder with the Salamander S-Flange. However, having never worked on the cylinder before, I'm not sure what the procedure is.
Once the cylinder is emptied, I guess the procedure is as follows:
1. Disconnect the wiring from the immersion heater and remove the heater with the box spanner that I just got from the plumber's merchants. I'm hoping this won't be too tricky.
2. Disconnect the copper pipe that connects to the existing flange.
3. Use the hole created by removing the immersion heater to gain access to the lower nut of the existing flange. This seems pretty tricky to me as the immersion heater doesn't appear like it will offer a great deal of access.
4. Install new S-flange. Again, this appears tricky as the nut to tighten the flange in place will be on the inside of the cylinder.
5. Refit immersion heater.
Any tips (especially on points 3 and 4) would be gratefully received.
Cheers,
iep
Cheers,
iep
