Hi again,
After my blockage woes in the other thread this week (thanks again to those of you that contributed), I'd like to replace the flexi pan connector with rigid.
The current McAlpine flexi connector connects to the pan on one end and is just pushed into the ground waste on the other end (ground floor toilet).
I'm not sure if a normal rigid pan connector will reach the outlet on the toilet as it's quite short.
That being the case, can I combine these two in order to reach the outlet on the pan?
https://www.screwfix.com/p/mcalpine-rigid-90-angled-wc-pan-connector-white-240-340mm
https://www.screwfix.com/p/mcalpine-rigid-straight-telescopic-wc-socket-extension-white-138mm
I don't plan on having to redo any of this for quite some time so want to make sure it's right.
Thanks in advance.
Thanks in advance.
