Replacing garage back door and window - FENSA?
4 Sep 2011
Shropshire
I'd like to replace my garage door and window at the rear of the garage with upvc.
Does it need to be installed through a FENSA fitter / notify LABC?
The garage is single width is attached to our detached property.
There is no access between the house and garage you gave to go outside via back door and is only single story (no rooms above)
Many thanks.
You don’t need to notify or use a FENSA registered installer for fitting a new garage door & it doesn’t need to be double glazed either unless that’s what you want. Any glazing panels must be toughened safety glass.
