Hello,
our four buner Gas Cooker hob is quite worn out, after 25 years of use. The gas on the front two cookers has reduced, however the rear two is fine, as they were used less.
I want to replace this. But I am not sure what size I need.
The measurement of the cooker is 58cm width wise, on the outside.
I would like a five ring burner, however they require you to make the area bigger. So I am sticking with a 4 ring burner.
However, do I need a Gas Safe engineer to install this for me?
If so, what would be the typical cost for this type of job?
The one I have seen and like is a black Indesit 4 hob burner - PIM 640 AS.
Thanks again.
Thanks again.
