Replacing Gate Valve
10 Dec 2008
Cheshire
I have a leaking gate valve in my airing cupboard.
The valve is in lower return (?) pipe from the HWC. I have tried nipping this up but made it worse.
Have no problem replacing the valve but my question is how to isolate the valve.
I can see there is another valve downstream before it tees into the 22mm pipe just after the pump so i guess i could turn that off.
There is also valves in the 22mm feed pipe that goes into the HWC again further down around the 3 way valve.
Any ideas?
Thanks Andy
Could you explain whats involved with a "drain down"
Also why the change in valve type?
Cheers
