- Joined
- 29 Jan 2015
- Messages
- 6
- Reaction score
- 0
- Country
I've read a bunch of other threads but I'm still not 100% sure I know how to wire up the Nest Heat Link correctly and obviously don't want to blow up my £179 shiny new gadget!
The Honeywell T40 has 3 wires coming in which as far as I am aware correspond to:
1 - [live]
2 - [neutral]
3 - [switched live]
The Nest heat link requires these connections:
Live connected to "L"
Live connected to "2 [common]"
Neutral connected to "N"
Switched Live connected to "3 [call-for-heat]"
[see pages 32 & 34 of installation manual: https://s3.amazonaws.com/support-as...ges/Nest-Thermostat-Installation-Guide-UK.pdf]
So does that mean the corresponding wiring should go:
[code:1]Wire *was* here in Honeywell -------- Wired *now* to here in Nest heat link
1 [live] ---------------------------- 2 [common] with jumper cable to L, as specified in Nest manual
2 [neutral] ------------------------- N
3 [switched live] ------------------- 3[/code:1]
Thanks in advance for any help you can give me!
1 - [live]
2 - [neutral]
3 - [switched live]
