replacing honeywell t6360 with dt92e
1 Aug 2008
Hi, I would like to replace my stat with a wireless one and would like to know if this is straightforward or not.
The current stat (t6360) has 3 wires
1 = Red
2 = blue
3 = yellow
not to sure were the wires go in the new stat (dt92e) as i have read somewhere that it possibly only needs 2 wires.
My boiler is an ideal icos with a 3 port valve and a st6400c programmer.
Thanks for any help.
Do you mean wireless or a simple digital stat? The wireless type have a relay box to install and wire with a permanent live plus control wiring.
92 e is wireless
you want a wired dt90 if you want straight change
hi, I would like a wirelees stat as the old one is far away. If it is complicated or I cant use the same wires I probably wont bother.
thanks.
