Hi All,
I searched the forum to find an answer to the problem i am having but couldnt find an answer.
//www.diynot.com/forums/viewtopic.php?t=245061
I removed the old thermostat and fitted the new one, only connect the live wire to terminal A on the new stat and the switched live wire to terminal B. I isolated the neutral wire and the earth wire and left these unconnected.
My system is:
Valiant Ecotec conderser bolier. and there is a junction box which the honeywell ST699 programer, boiler, room stat, cylinder stat and two motorised valves (one for CH before the manifold and one for HW) all connect to.
I'm not an expert on heating systems by any means though, but i think this is a sundial s plan???
I have left the CH on constant on the programmer, however although the CM901 room stat shows the burner on symbol on screen, the boiler does not fire up, i dont think the valve for the CH moves either. There is a flashing radiator symbol on the boiler which i think means that it is not getting a heating call.
The boiler does work for HW however.
i would be very grateful if someone could let me know if i have connected it incorrectly. do I need to change the wiring in the junction box? If so i think i will call out an electrician.
Many thanks
amar
My system is:
Many thanks
amar
