My old bath is served by a 22mm hot water pipe (historically fed from a gravity system I think). Anyway it is now served by a combi in the next room (downstairs kitchen) and hot water from combi is 15mm which then connects to the 22mm pipe in bathroom. I am thinking of replacing all of the water pipes in bathroom for various reasons to do with layout. I am guessing that I can use 15mm for hot throughout as the present 22mm does not increase flow because of the 15mm beforehand. Am I right to use 15mm which would be easier for me?
Also can I use flexible plastic for hot water?
I will also be fitting a mixer shower (and I know that there are potential problems ahead eg I may have to reduce my mains pressure but I'll be optimistic for now)
Finally I am reasonably competent and have done two kitchens in the past. I usually get by with copper and compression joints but I want to give plastic a try this time.
