Current imperial radiator measures roughly 1330mm with roughly 1420mm between pipe centres.
I don't want to pull up the laminate, so cannot shift the pipes.
Is my best option to get a 1300mm rad, and then use some short tail extensions? I think I will only need to make up around 30mm in total (so 2x 15mm extensions).
Does this make sense?
