was just about to replace a ropey old floor with new chipboard flooring but have discovered some of the old joists are rotten (spongy) at the ends and the wall plates are the same. The wall plate is not fixed in any way either and is levelled on slate.
This is a ground floor by the way.
I want to replace the lot, and re-level on bricks.
Should I bed the new joists ion cement and use a dpc? If so, where - between brick and wall plate?
How do I fix wall plate at it's ends? Can I just use L brackets to stop any lateral movement as there's no room for hangers and the load will be taken by the bricks.
