Hello
I want to replace the laminate in my kitchen (with new laminate of same thickness). Unfortunately the owners before me fitted the laminate before the kitchen, and it goes back to the walls. In my mind I have 3 options:
1. Lay new laminate on top of old laminate, up to the feet of the units and cover with trimmed kickboards.
2. Physically cut-out existing laminate up to the line of the unit feet (using mini-circular saw with depth gauge set to 9mm) and fit new laminate. Kickboards will hide the join.
3. Try and gently raise the units by 1mm (car jack??)/screw-up legs to pull out the existing laminate, and then slide new stuff under.
I know that any none of these are ideal, but I don't want to remove the kitchen units (they're in good nick, and the worktop is perfectly jointed and level). I am aware that the membrane/underlay might be damaged during the process.
Any suggestions as to which is the least cowboy-like option, and likely to give the best result?
