Hi
We have lead water pipe from the water meter/stopcock (which are both inside our property boundary) to the in-house stop-cock, which is a distance of about 20m.
Also the in-house stop-ck is in a very odd place (to to historic house extensions), so as part of some other building work we would like to replace this lead pipe/ relocate the in-house stop cock.
I understand the incoming water needs to be 25mm MDPE (blue) pipe, 750mm U/G and in a 100mm sleeve insulated and sleeved as it passes under the foundations to enter the house?
Luckily where is enters the house is the current front door (don’t ask!!), but we are relocating the front door and this will then become a window. Also the front door is a double pourch type affair, so I can remove the external door section, still leaving a sealed door to the house whilst I work on the out side.
I can break up the current foundation section to get 750down, but where the lead is, is only about 20” down with some odd sort of lime scale unit in a pit with a man cover on.
I only want to part replace the pipe to this man hole which is only about 1m away, and then do the other approx. 19m at another time.
So I will have to dig down to 750 through the foundations, but bend back up to the current lead pipe level!!!
Also when I finaly get round to replacing the rest of the lead pipe, can I connect to the meter/stop-cock myself?
