Hi.
I am wondering whether it is worth replacing my mains pipework. Unsure if it is lead however have quite poor flow and working pressure which supplies a green star 36i combi boiler.
The water meter in street run about 15m underground to stop tap in kitchen back of house. Before that there is a tap in the garage at about 5m from water meter. The tap in the garage flows 18l/min and the stop tap in kitchen 10m on flows 14l a minute.
The static pressure is 2bar and working pressure to boiler hot water is 1 bar measured by Worcester engineer. It needs 1.6bar to work to max level.
I believe the underground pipe is 15mm lead or copper, would replacing as much as possible with 25 or 30mm actually improve the working pressure or flow once its connected to the 15mm pipe work around the house.
A quote to replace underground pipe to 7m from water meter (rest would mean digging up kitchen) with 25 or 30mm and make good the trench was given as £780.
Obviously I don't want to waste money on bigger pipes if it means nothing from a functional point of view, Id put that money towards a different solution. The United Utilities man didn't feel it would be worth it as he said pressure would stay the same, although he clarified he was talking about static pressure as that's all they measure.
Any advice much appreciated.
