Hi
I have just brought a chalet bungalow that has microbore with 10mm (of imperial equvalent) throughout downstairs, I want to modernise the system and fit the radiators with Thermostatic Valves, a couple of queries.
1) My simple plan is to remove the manifold and run a pair of 15mm pipes (in plastic) in a circuit servicing the downstairs rads (7 in all) with perhaps the need for a bypass valve at the start of the circuit.
2) The old radiators are all double entry, can I reuse them. One end is blanked off with a square key, I assume I can remove and fit a pair of locknut and TRV valves? If possible is this advisable? would I be better getting newer radiators in terms of efficiency? the old ones are quite sizeable compared with more modern installations, but if I can reuse I would save a good few pounds.
Does this sound like common sense approach? I am not a plumber as you can tell but like to try these things (the house is empty and I am gutting it so now is the ideal time to do this work!)
Cheers
Rob
Cheers
Rob
