For some time we have had a portion of mortar cracked and come loose on the outside of the door frame where over time the door has been slammed and worked it loose. Now it has finally fallen out - see attached pic.
Question is - what is the best way to repair this? I have read about using a foam filler to fill the gap between frame and brickwork - there is a small gap here. Also that we should not use mortar since it will always crack and fall out again - but if that is the case what should we be using? Also read about mixing mortar with a glue of some sort, or using a mastic filler?
Any advice greatfully received.
