After a posting here (along with useful replies) and a visit from a Heating Engineer I have decided to have my 13yr old boiler replaced.
From reading here I realise that the existing boiler will have to be replaced with a condensing boiler. I noticed several postings here mentioning "pluming" from these condensation boilers due to lower exhaust gas temperatures. The boiler will be situated in a cupboard at the front of the house with the flue exiting the front of the house directly out of the front wall.
The existing flue is approx 6.5' of the ground and approx 50cm from the edge of a shared arched doorway at the front of the house. I haven't had an problems with the existing flue but what concerns me is that the plume from the new boilder will blow onto the shared doorway affecting both myself and more importantly the neighbours.
From posts here I have seen distances of 600mm and 2.5m for distances from doorways and footpaths. From one of the posts I noticed it seems that if you install one of these flues within 2.5m of a doorway or path and neighbours complain it's a problem.
Obviously the Heating Engineer who is will be installing the boiler will be able to tell me what his opinion is on the location of the flu but I would appreciate others experience/opinions. Specifically:
1. Do you think having a flue this close to a doorway and path will be a problem.
2. Is there any way of diverting the flu gases away from doorway?
3. I read that it is possible to get a non-condensing boiler installed in exceptional circumstances. One factor being "pluming" near a doorway or footpath. A soakway (with lime e.t.c) will also have to be fitted as there is no drainage nearby to catch the condensate. A non-condensing boiler would be considerably easier to have installed (not necessarily better of course).
4. Is it even worth trying to raise this as an exception to get a non-condensing boiler?
Thanks in advance
Martin
Thanks in advance
Martin
