Replacing old Honeywell EE4 with Honeywell CM927 - HELP
28 Nov 2009
Northamptonshire
I replaced my old Honeywell thermostat with a new CM927 today but... it doesnt work... Power light is on - remote thermostat turns unit on at right temperature, but boiler doesnt fire up... I have reinstalled the old thermostat in case I had blown a fuse somewhere but that works perfectly.
Wiring on old unit goes 1 to 5
and wires go into 1 = Permanent live 2= neutral 3= switched live.
There are four wires going into the unit - two live and two neutral
The new unit has six slots N L L A B C
I wired 1 into L, the 2 neutrals into N and the switched live into B....
So why isnt it working? :evil:
Ok - sussed it !
Had to put a bridging wire from second L connector to A - Stupid design if you ask me - and would have been soooooo easy to mention that L and A both need permanent live feeds!
you've only give us 3, very much doubt you have 2 neutrals.
just cause it maybe blue don't assume its a neutral.
N - NEUTRAL
L - PERM LIVE
A - LIVE
B - SW/L
There were 2 neutrals - twisted together and plugged into the same connector... dont know exactly why... but left them hooked together and sharing the neutral connector spot....
Thanks for your help :D
Ok - sussed it !
I assume not everyone may want a feed there, as they may want to series it up in a control circuit or even a Lower voltage circuit.
They used to fit links in timers and advise to remove if not needed.
Nice looking unit, may get one myself.
