I will be getting the keys for my 1907 terraced house in a couple of weeks and my first job will be re-fitting the bathroom, which appears to have been untouched since the 60s! I've reading posts on this site for a while now in preparation for the work, it's been a very helpful experience, but I was wondering if I could clarify a couple of things.
There is currently floor to ceiling tiling that I'm planning to remove and replace with a half-tiled, half-painted surface, except around the showerbath, which will be fully tiled. I believe the bathroom has solid brick walls, of which two are external and two internal. I'm not sure what the surface will be like behind the current tiles (I'm trying to get as much of the materials ready before starting).
Seeing as I've not done any form of plastering before, I was thinking it would be worth installing plasterboard rather attempting to skim the existing wall to provide a surface for the painting (using MR board, with tanking around the shower).
Would I be right in saying that I would have to batten the external walls rather than dot & dabbing the PB? If so, would this be an opportunity to add some insulation to the walls?
Many thanks ,
Andy
Many thanks ,
Andy
