Hi
I live in an end of terrace Victorian house that has suffered bowing to the external side wall at some point. This has been remedied by the installation of the old style wall ties consisting of an external metal disc that is bolted to a large threaded bolt which is in turn welded to a flat metal bar that is screwed across the top of a number of floor joists. There are four ties equally spaced at both levels.
I have discovered that one of these metal bars has been shortened considerably by a builder we had to do some work in the loft in order that he could relocate the access hatch. I now only screws into 1 joist.
Would it be possible to have this strengthened by removing the old disk and using one of the newer rods drilled through the joists and secured using epoxy? Also would this be possible to do externally without having to lift the floor in the loft room above the joists?
