Hi all,
I am planning to replace my intruder alarm panel and was wondering if there is a way to isolate the bell box in some way to prevent it from sounding when the power, the back-up battery, and the bell box itself are disconnected from the panel.
I was thinking that after isolating the mains supply then opening the panel and resetting the system, could another 12 Volt battery be connected across the +ve hold off and 0V hold off wires to the bell box? Then keeping these new connections intact, disconnect the bell box from the panel?
Would the switched activation feeds to the strobe and sounder need to be connected to hold-off resistors?
The existing panel is an Advantage ZX6, the Bell Box is a Flash Guard by Klaxon.
Thanks in advance for any replies.
