I would like to replace the piping to some radiators to improve its appearance. My system has a Worcester 24i combi boiler and uses 10mm piping. I have a wall-mounted thermostat. Most radiators have piping that comes down the wall to them. There is no draincock on my system. I would be grateful if someone could read over what I am planning to do and provide comments, as some stages I am a bit unsure of. I am totally new to central heating, so please be patient. Here's what I have planned:
1. Turn off boiler on front panel. Turn off wall-mounted thermostat.
2. Turn off mains supply to boiler. Not too sure how to do this as there is only one water stopcock in my house. Do I simply turn this off?
3. Turn off electricity supply to boiler at mains board. Check light is out on boiler.
4. Isolate lowest radiator at both ends. Remove thermostatic valve, catching water that will escape. Attach valve with drain-off to radiator. Attach hose and drain off by opening lockshield valve.
5. Open bleed valves on all radiators until system fully drained.
6. Replace pipework.
7. Turn Mains supply back on (after closing bleed valves).
8. Turn electricity to boiler back on at mains board.
9. Turn boiler on and turn wall-mounted thermostat to full to re-fire boiler.
10. Re-set thermostat and boiler temp.
My system also contains Sentinel X100 inhibitor that was put in in January 2003. Will I have to do anything different because of this? Would it be wise to replace this, and if so how would I go about it? Thanks for any help.
