Before Wednesday of this week we had nasty, old polystyrene ceiling tiles and matching coving in both our bedrooms. The titles and coving have been pulled down and the ceiling has been skimmed by a plaster.
So, now I have to put up some new coving... I've searched around a bit, however your input/guidance would be appreciated.
I'm planning to follow this guide and use polystyrene coving because:
Lightweight (I'll be doing it on my own)
Easy to cut
Flexible so it shouldn't crack when/if the walls and ceiling move
It will mould to any unevenness on the walls
Some questions:
1) Once painted, will polystyrene coving look like polystyrene (i.e. a bit nasty/tacky) ? A clean, smooth finish is what I'm after. If polystyrene can't provide this, is there an alternative that's easy to use and available in high-street DIY shops (B&Q, Wikes, etc)
2) I bet these walls aren't true, so two 45 degree cuts won't line up perfectly. Should I a) cut two 45 degree angle and fill any gaps later or b) attempt to cut odd angles so they match perfectly?
3) Does it matter where I start/finish in the room? The master bedroom has internal and external corners.
4) On straights, should I butt pieces together or mitre them?
Edit:
5) On this page what measure does 127mm refer to, a or b?
[code:1]
a.
__________
| / b.
[/code:1]
Easy to cut
Some questions:
Edit:
[code:1]
a.
__________
| / b.
[/code:1]
