Hi. I have a Riello 40 G3B burner and have been advised to replace the pump. My burner has a ram which I wish to keep connected to the pump. Can anyone tell me how to replace the pump? Cheers.....
I think you are referring to the fact that the connection for the ram missing on your new pump????? if you look at the Nozzle line connection, below is a 1/8" plug, this is the revised position for the ram (personally i'd throw the ram away and run the burner without it (you have to remove the brass insert from the damper fulcrum so that you can lock the damper flap in the correct position))
