I have been scouring the previous topics and it doesn't seem to have been a problem for anybody else so I hope this is very simple:
I am replacing a radiator in my bathrom. I want to replace it with a chrome 'towel-rail' style radiator. However, the new radiator has different connections at the bottom, which means I'll have to replace the valves.
The valves need to enter the new radiator vertically, from the bottom, unlike the old one, where they entered the side of the bottom of the rad.
I have bought new valves, which come up vertically from the pipes out of the floorboards and would go straight into the rad.
I have taken the old rad off by closing the old valves off at either end, then undoing the connections betw the valves and rad, and lifting it off the wall. I am now left with two pipes and closed valves sitting free.
My question is: How do i now take the old valves offand put the new ones on without water spurting everywhere?!
I've got a combi boiler and have switched off the mains water inlet under the sink so at present none of the taps work. I've checked that all the other rads are switched to zero on their thermostats and that none of the bleed valves are open, so I thought there wouldn't be any way of air getting in to replace the water that spurts out. (and it comes with quite some force so I don't think its just a bit leftover coming through).
Please can somebody help?!
Thank you!
Thank you!
