Replacing Radiators - Advice Please
1 Mar 2011
West Glamorgan
probably give you an extra 500watts, thought about putting another rad somewhere else in the room?
You could try radcalc.com to see if the radiator is sized correctly first then you won't be wasting any money buying a radiator that you don't need.
If the radiator is sized correctly there maybe another reason why it isn't reaching temperature like a balancing issue or a faulty TRV.
Thanks both the room is
4.8m long
2.6m high
3.6m wide
Double Glazed Window
Not north facing
Suspended timber floor
Unfilled cavity wall - room 2 outside walls
Cant really get another radiator in the room but looking at the B&Q radiator calculator would the Myson BTU of 5885 be ok
http://www.heatandplumb.com/acatalo...00mm_High_x_1400mm_Wide_Double_Convector.html
or would the Quinn Barlo be better
as its got a higher BTU ?
With room sizes you've given, and assuming double glazed, and average temp needed in the room, Radcalcs gives a requirement of 10075 BTU's. The Quinn Barlo is still well short of that figure. :cry:
You're going to need a rad a lot bigger to achieve that sort of output I think, and if it is your lounge then you're possibly going to prefer it on the warmer side anyway, which would means more BTU's from a rad. What is the problem with fitting a rad on a different wall in the room?
Thanks but the new rad should be better than the one that is currently there as shown in the pic?
As for adding a new rad the only one that would fit is a slimline vertical radiator but would the pipe work cost much as it would have to be run under a suspended wooden floor which they could crawl under as the flooring would not be able to come up
Without knowing the output of the rad in situ it's difficult to say. The current rad looks quite modern, if it has a series of metal fins between the 2 panels then it'll be a doble panel/single convector and anything else that'll fit in that space may only give a marginal (possibly unnoticeable) difference.
You've a carpeted floor, it should be possible to peel back the carpet in one or two places and thread a couple of pipes under the floor to suit a new position for another rad should you choose. Concrete floors pose slightly more of a problem!
