Just moved into a new (1980's) house which has replacement windows. Some of the windows are obviously older than others and have various problems. The window to the bathroom has dirt between the panes. Trying to compare this to the others I see that the black rubber "beading" on the inside, is just one long strip, bent at the corners. In one corner is a small gap. The beading on the outside seems to be okay, it's in four strips, the same as the newer replacement windows.
Now for the question!!!
Can I strip out the old beading, clean the window panes and replace with new beading? Or do I need a whole new unit?
Whatever the answer is, how do I do it???
