REPLACING ROOM THERMOSTAT
11 Oct 2003
Iam replacing a mechanical room thermostat with a digital one.The terminals on the digital are NO,com,and NC.My existing wires are live,neutral and switched live.Could someone please advise me which goes where?
Neutral is not required for a digital room stat (but bateries usualy are (mine has) you should put the neutral wire in a coc bloc, and connect the live and switch wires to C (common) and NO (Normaly Open)
Thats great,thanks.Could you explain what is a coc bloc? for the neutral
sorry, its just a "common name" for connector strip
He means " choc Blloc" ie Chocalolate block , used to be black but now ANY colour
Thanks for all your help.It is now wired and working perfectly
